"Restores all paints, removes & reverses oxidation, and fills in scratches." Glassplexin actually fills in the surface scratches and reverses oxidation to bring the painted surfaces to a new level of beauty not available with any other compounds. Creates a shine so bright you'll need sunglasses!!
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
