Quick view Caswell sku: BOCONC1Q BLACK OXIDE CONCENTRATE 1 QT MSRP: Now: $70.14 Add to Cart Compare Quick view Caswell sku: BO1 Black Oxide Kit - 1.25 Gal MSRP: Now: $102.34 Choose Options Compare Quick view Caswell sku: BOCONC1P BLACK OXIDE CONCENTRATE 1 PINT MSRP: Now: $42.54 Add to Cart Compare Quick view Caswell sku: BOACT1P Black Oxide Activator 1 Pint (Makes 1.25 Gallons) MSRP: Now: $25.29 Add to Cart Compare Quick view Caswell sku: BOACT1Q Black Oxide Activator 1 Quart (Makes 2.5 Gallons) MSRP: Now: $44.26 Add to Cart Compare Quick view Caswell sku: CMB Caswell Mega Black™ Kit MSRP: Now: $150.54 Choose Options Compare Quick view Caswell sku: BO2 Black Oxide Kit - 2.5 Gal MSRP: Now: $188.59 Choose Options Compare Quick view Caswell sku: CMB1Q Caswell Mega Black™ Concentrate - 1 Quart (Makes 2.25 Gallons) MSRP: Now: $88.53 Add to Cart Compare Quick view Caswell sku: CMB1P Caswell Mega Black™ Concentrate - 1 Pint (Makes 1.125 Gal) MSRP: Now: $50.59 Add to Cart Compare Quick view Caswell sku: BOCONC1G Black Oxide Concentrate - 1 Gallon MSRP: Now: $261.04 Add to Cart Compare Quick view Caswell sku: BO5 Black Oxide Kit - 5 Gal MSRP: Now: $278.29 Choose Options Compare Quick view Caswell sku: BOCONC5G BLACK OXIDE CONCENTRATE 5 GAL MSRP: Now: $871.69 Add to Cart Compare Quick view Caswell sku: HCK Heat Coloring Kit For Steel & Stainless Steel MSRP: Now: $63.24 Add to Cart Compare Quick view Caswell sku: BOCONC55G BLACK OXIDE CONCENTRATE 55 GAL Compare Quick view BLACK OXIDE CONCENTRATE 1 QT Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 1 quart of concentrate makes 2.5 gallons of blackening solution... MSRP: Now: $70.14 Add to Cart Compare Quick view Black Oxide Kit - 1.25 Gal Blacken Steel Or Iron Parts At Room Temperature This new technique was developed by the commercial gun blue manufacturers as a more environmentally friendly system than the commonly used hot application. Parts requiring blackening are simply placed in... MSRP: Now: $102.34 Choose Options Compare Quick view BLACK OXIDE CONCENTRATE 1 PINT Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 1 pint of concentrate makes 1.25 gallons of blackening solution... MSRP: Now: $42.54 Add to Cart Compare Quick view Black Oxide Activator 1 Pint (Makes 1.25 Gallons) Black Oxide Activator Product does not perform blackening. It is an activator for use before blackening. Certain hardened or specialized steels can prove challenging to blacken with our Black Oxide solution, only blackening to a grey color. Our Black... MSRP: Now: $25.29 Add to Cart Compare Quick view Black Oxide Activator 1 Quart (Makes 2.5 Gallons) Black Oxide Activator Product does not perform blackening. It is an activator for use before blackening. Certain hardened or specialized steels can prove challenging to blacken with our Black Oxide solution, only blackening to a grey color. Our Black... MSRP: Now: $44.26 Add to Cart Compare Quick view Caswell Mega Black™ Kit Caswell Mega Black™ Blackening Kit Deeper, Darker FinishCan Be Shipped Worldwide and by AirRoom Temperature Blackening Of SteelNo Dangerous Fumes Or Corrosive Chemicals Our NEW Caswell Mega Black™ is the most advanced blackening... MSRP: Now: $150.54 Choose Options Compare Quick view Black Oxide Kit - 2.5 Gal Blacken Steel & Iron Parts At Room Temperature This new technique was developed by the commercial gun blue manufacturers as a more environmentally friendly system than the commonly used hot application. Parts requiring blackening are simply placed in... MSRP: Now: $188.59 Choose Options Compare Quick view Caswell Mega Black™ Concentrate - 1 Quart (Makes 2.25 Gallons) Concentrate Only Mix with 2 Gallons Distilled Water for immersion blackening of steel and iron parts. Does not work on Stainless Steel. MSRP: Now: $88.53 Add to Cart Compare Quick view Caswell Mega Black™ Concentrate - 1 Pint (Makes 1.125 Gal) Concentrate Only Mix with 1 Gallon Distilled Water for immersion blackening of steel and iron parts. Does not work on Stainless Steel. MSRP: Now: $50.59 Add to Cart Compare Quick view Black Oxide Concentrate - 1 Gallon Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 1 gallon of concentrate makes 10 gallons of blackening solution... MSRP: Now: $261.04 Add to Cart Compare Quick view Black Oxide Kit - 5 Gal Blacken Steel & Iron Parts At Room Temperature This new technique was developed by the commercial gun blue manufacturers as a more environmentally friendly system than the commonly used hot application. Parts requiring blackening are simply placed in... MSRP: Now: $278.29 Choose Options Compare Quick view BLACK OXIDE CONCENTRATE 5 GAL Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 5 gallons of concentrate makes 45 gallons of blackening... MSRP: Now: $871.69 Add to Cart Compare Quick view Heat Coloring Kit For Steel & Stainless Steel Color steel and stainless steel parts by heat treating and oil quenching Possible colors include yellows, browns, purples and blues. Our Heat Coloring Kit Includes Casweld™ Keep Kool™ Putty, which prevents heat from travelling up your pliers or other... MSRP: Now: $63.24 Add to Cart Compare Quick view BLACK OXIDE CONCENTRATE 55 GAL Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 5 gallons of concentrate makes 45 gallons of blackening... Compare Compare Selected × OK
