null
Lab Metal®
  • HIGH TEMP LAB METAL 24OZ
    Hi-Temp Lab-metal® Repair compound for high heat applications. One-part metal putty able to withstand temperatures to 1000°F. Apply directly from the can with a putty knife. Can be machined, ground, filed, and sanded. Repairs items prior to lengthy...
    $103.49
    Out of stock
  • High Temp Lab-metal 24 oz & 1 Pint Solvent 24 oz High Temp Lab-metal 24 oz & 1 Pint Solvent 24 oz
    $119.59
    Add to Cart
  • LAB METAL - 12 OZ CAN
    Lab Metal® repair putty Ready-to-use aluminum-filled repair and patching compound. Spreads like paste, hardens into metal. Adheres to metal, wood, plastic, glass, fiberglass and more. Apply right from the can. No mixing of two parts, no measuring or...
    $41.39
    Add to Cart
  • LAB METAL 24OZ CAN
    LAB METAL 24OZ CAN
    $57.49
    Add to Cart
  • Lab-metal 12 oz & 1 Pint Solvent 12 oz Lab-metal 12 oz & 1 Pint Solvent 12 oz
    $63.24
    Add to Cart
  • Lab-metal 24 oz & 1 Pint Solvent 24 oz Lab-metal 24 oz & 1 Pint Solvent 24 oz
    $80.49
    Add to Cart
  • LAB-SOLVENT - 16 OZ
    LAB-SOLVENT - 16 OZ
    Lab-solvent Thinner for Lab-metal, metal cleaner. A blend of solvents for thinning Lab-metal to paint consistency for brushing or spraying. Surfaces cleaned with Lab-solvent provide superior adhesion for Lab-metal and Hi-Temp Lab-metal. Cuts and...
    $18.96
    Add to Cart
