Hi-Temp Lab-metal®
| Repair compound for high heat applications. One-part metal putty able to withstand temperatures to 1000°F. Apply directly from the can with a putty knife. Can be machined, ground, filed, and sanded. Repairs items prior to lengthy or repeated powder coating processes. Ideal for repairs in powder coating, metalworking, welding, fabricating, heating, construction, die casting, and mold refinishing which may be subjected to high temperatures. Used to repair fabricated parts, core boxes, boilers, mufflers, exhaust systems, molds, wood and coal burning stoves, grills, engines, radiators, and industrial ovens. Packaged in 24 oz. containers. |
Hazardous Shipping Info
