Lab-solvent
| Thinner for Lab-metal, metal cleaner. A blend of solvents for thinning Lab-metal to paint consistency for brushing or spraying. Surfaces cleaned with Lab-solvent provide superior adhesion for Lab-metal and Hi-Temp Lab-metal. Cuts and flushes oil, grease, and dirt off of precision tools, bearings, gears, motors, condensers, controls, and other valuable equipment. Leaves no film and does not corrode. Packaged in pint containers. |
All Lab-Metal and Hi Temp Lab-Metal products are sold with a pint of Lab-Solvent. This solvent is used to:
- Clean the metal prior to application.
- Thin the product
- Keep the product from drying out after opening. Pour a small amount of Lab-Solvent in the can after use.
Hazardous Shipping Info
