LAB METAL - 12 OZ CAN
Lab Metal® repair putty
- Ready-to-use aluminum-filled repair and patching compound.
- Spreads like paste, hardens into metal.
- Adheres to metal, wood, plastic, glass, fiberglass and more.
- Apply right from the can. No mixing of two parts, no measuring or heat required.
- Lab-metal can be milled, drilled, tapped, ground and sanded smooth.
Will not shrink or crack. Water resistant, rustproof. Withstands heat to 350°F (higher for one-time powder coating exposures). Thin with Lab-solvent for brushing or spraying. Many applications may be made from a single can -- simply add Lab-solvent before covering. Spreading or shaping Lab-metal (auto body work, sculpturing) is enhanced by keeping applicator moist with Lab-solvent while spreading. Durable, permanent filler for patching seams and cracks; rebuilding worn metal surfaces; repairing dented metal; finishing welds; filling holes and imperfections in metal castings. May be powder coated for single exposures up to 420°F, no longer than 20 minutes.
Packaged in 12 oz., 24 oz.
Hazardous Shipping Info
