The T14 is a semi-automated tumbling blast cabinet. The parts basket is welded steel and has arms that help tumble parts equally during the process.
The parts basket has a weight capacity of 24 pounds and easily loads and unloads. The 14 CFM blast system is activated when the window is closed and the timer is turned on.
The basket features ridges that help turn the parts over as they are blasted. It also has small perforations that lets media and debris fall out, but not parts!
| Overall Dimensions | 50” (h) x 30” (w) x 20” (d) | |
| Working Dimensions | 27” (h) x 52.5” (w) x 29.5” (d) | |
| Window Dimensions | 25” (w) x 10” (h)” | |
| Construction | Welded 16 Gauge Steel | |
| Blast System | 14 CFM @ 70-90PSI | |
| Blaster Operation | Timer Operated | |
| Motor | 6.9 RPM | |
| Electrical | 110Volts | |
| Dust Collector | Sold Separate: 90 or 400 CFM | |
| Weight | 250 Pounds | |
| Origin | Made In The USA | |
