Overall Dimensions: 58" (h) x 48 1/2" (w) x 48" (d)
Working Dimensions: 26" (h) x 48" (w) x 26" (d)
Side Door: 18" x 12"
Window: 25" x 10"
Construction: 16 gauge steel
Gun Assembly: Foot operated: 14 CFM @ 90-100 PSI
Electrical: 110 Volts
Dust Collector: DC1500
Weight: 275 lbs. (common carrier)
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
