Overall Dimensions: 60" (h) x 45" (w) x 46" (d)
Working Dimensions: 24" (h) x 42" (w) x 24" (d)
Side Door: 18" x 12"
Window: 9" x 20"
Construction: 16 gauge steel
Gun Assembly: Trigger operated: 14 CFM @ 90-100 PSI
Electrical: 110 Volts
Dust Collector: DC1500
Weight: 245 lbs. (common carrier)
