PT100 Pressure Blaster
- Sand Capacity: 100 lbs.
- Tank Diameter: 12"
- Tank Height: 23"
- Overall Height: 29"
- Hose: 10 feet of 1/2" ID Hose
- Nozzle: 1/8" Ceramic
- Air Requirements: 23 CFM @ 100 PSI
- Shipping: 69 lbs. UPS
- Misc: Gauge-pressure relief valve, Goggles
