GLARE DA Pro Polisher
NEW GLARE DA Pro Polisher 900 Watts of Power Variable Speed
Special Pricing With Glare Red and Black Anniversary Buffer Bag Embroidered Logo - Plus a Free Bottle of Glare Polish, and a Glare Micro-Fiber Towel - For a Limited Time Only!
Light Weight and easy to use, even if you never used an electric Buffer before, or you're a Pro. This machine is built to take it! A Beautiful Buffer that you will use for all your buffing, and sanding needs.
Comes in a special limited edition Custom GLARE Black & Red Utility Bag that holds your Buffer, Pads, and of course your GLARE Pro Polish Products.
- 900 watt,(not 500 watt like the others)
- Heavy duty all ball bearing electric motor.
- Variable speeds Ranging from 2500 to 6000 orbits per min.
- Equivalent to 0-2,800 RPM.
- This is a Random High Speed Orbital Buffer.
- Will not burn paint.
- Comes complete with a Center Handle as well.
- Also included is a Free Bottle of GLARE Pro Polish, plus our best seling 2 foot by 2 foot GLARE Huricane Micro-Fiber Towel, and the free GLARE Limited addtion Bag no charge.
- Total Retail Value $64.95 no charge. (6" BUFFING PADS ARE NOT INCLUDED)
