Kit Includes:
- 1 x Jumbo Black Compound
- 1 x Jumbo Brown Compound
- 1 x Jumbo White Compound
- 1 x Jumbo Green Compound
- 1 x Jumbo Red Compound
- 1 x Jumbo Blue Compound
- 1 x 8" x 7/8" Sisal Wheel
- 1 x 8" x 7/8" Spiral Sewn Cotton Wheels
- 2 x 8" x 1/2" Loose Cotton Wheels
- 2 x 8" x 1/2" Domet Flannel Wheels
- 1 x Grinder/Buffer Adapter (fits onto 5/8" shaft - accepts buffing wheels with 1/2" hole)
- Buffing and Polishing Booklet
This kit contains everything you need to polish metal or plastic using a handheld grinder/buffer. The included adapter fits onto grinder/buffers with a 5/8" shaft (this is nearly all machines in existence) and allows the buffing wheels to be mounted on the grinder. It gives ample working room for any buffing job.
The included wheels and compound give you a complete tool kit to polish almost any material, including aluminum, checker plate, steel, stainless steel, copper, brass, gold, silver, plastics and even wood.
Perfect for polishing trailers, truck wheels, railings and other larger jobs.
If you plan on polishing with a grinder/buffer, this is the only kit you'll need.
HANDHELD GRINDER BUFFING KIT 8"
Shaft extension is idea for by variable speed grinder that goes down to 1800 rpm.. Six wheels match the 6 compounds. Great starter if you have a suitable (not too fast) grinder.
Great Kit!
The best beginner polishing kit available! 6 different large bars of compound with wheels for each, the handheld polisher adapter, and a how to booklet to get started. Plenty of products to experiment with for the money.
