One Pint will strip one x 10 Gallon Tank
Please Note - This product contains Methylene Chloride which is BANNED for consumer use. This product is only available for Business Use. All orders not shipping to a business address will be cancelled.
Remove old Caswell Gas Tank Sealer from your tank easily.
- Pour in enough product to swish around and cover entire surface
- Let sit for 30 minutes
- Rinse with water and soap
- Shake dry wall screws to loosen Sealer
- Repeat steps 1-4 until all sealer is removed
Safe for all metal, plastic and fiberglass tanks.
WARNING - Will remove all existing paint from the outside of the tank. Mask any existing coatings you do not want removed.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
GHS Info
![](/content/images/ghs_carc.jpg)
![](/content/images/ghs_harm.png)
SDS
