This special degreaser for Aluminum quickly cleans any aluminum alloy without etching. Mix 10 lbs of cleaner with 15 gallons of distilled water in a stainless steel container. Heat to 130 deg F on a hotplate. Immerse aluminum parts for 3-10 minutes prior to anodizing or zincating. Rinse after use and check cleanliness with the waterbreak test.
GHS Info
SDS
