CHEMICAL MIST SUPPRESSANT (For Chrome Plating)
A chemical frothy blanket that actually floats on top of the chrome, virtually eliminates all misting when used with Fume Control Balls. Use one bottle per 2 sq ft of plating tank surface area.
Note: Mist Suppressant is now premixed into our chrome plating activator.
For Anodizing, use our Anodize Mist Suppressant.
GHS Info
SDS
Great Safety Item
Works when used as directed... Keeps the plating area free of hazardous and corrosive fumes...
