null
Additional Items Required
Get Our Plating Manual
Plating Kits
  • FASTGOLD 24CT - 1 PT FASTGOLD 24CT - 1 PT
    FastGold 24ct and 18ct Gold Brush Plating Solutions FastGOLD is a new highly concentrated brush plating solution, designed especially for use with all types of brush plating machines, including pen platers. FastGOLD contains over 1 pennyweight...
    $1,499.29
    Add to Cart
  • FASTGOLD 24CT - 1QT FASTGOLD 24CT - 1QT
    FASTGOLD 24CT - 1QT
    $2,636.69
    Add to Cart
  • FASTGOLD 24CT - 4OZ FASTGOLD 24CT - 4OZ
    FASTGOLD 24CT - 4OZ
    $471.89
    Add to Cart
  • FASTGOLD 24CT - 8OZ FASTGOLD 24CT - 8OZ
    FASTGOLD 24CT - 8OZ
    $845.89
    Add to Cart
  • FastGold Brush Plating Solution 14K - 4 fl oz FastGold Brush Plating Solution 14K - 4 fl oz
    FastGold 14 Karat FastGOLD is a new highly concentrated brush plating solution, designed especially for use with all types of brush plating machines, including pen platers. FastGOLD contains over 1 pennyweight of gold per 4oz of solution, (2 troy oz per...
    $470.79
    Add to Cart
  • Fishing Lure Plating Kit - 1.5 Gal
    Everything You Need* To Plate Onto Lead Fishing Lures Easy 3 step process to a bright nickel or chrome-like finish. No cyanides or harsh acids Plates 1000's of lead fishing lures without replenishment Perfect for hobbyists or small businesses. Gives a...
    $361.89
    Choose Options
  • Fishing Lure Plating Kit - 3 Gal
    $482.89
    Choose Options
  • Flash Copper Plating Kit - 1.5 Gals Flash Copper Plating Kit - 1.5 Gals
    Flash Copper™ Plating Kit Improved Formula Provides Better Adhesion and Finer Plate Plates directly on steel, copper, brass, stainless steel, zincated aluminum, tin, nickel, electroless nickel and sulfamate nickel as well as die-cast zinc surfaces -...
    $228.79
    Add to Cart
  • Flash Copper Plating Kit - 15 Gals Flash Copper Plating Kit - 15 Gals
    $1,299.00
    Add to Cart
  • Flash Copper Plating Kit - 3 Gals Flash Copper Plating Kit - 3 Gals
    $265.09
    Add to Cart
  • Flash Copper Plating Kit - 4.5 Gals Flash Copper Plating Kit - 4.5 Gals
    $369.04
    Add to Cart
