Fine, Dome and Angle Point Detailing Wands
18 Reviews Hide Reviews Show Reviews
Good buy and they work great
I have used these now and find them perfect for smaller applications and where you don't need the shotgun effect of the regular wand. Not only did they give me pinpoint plating they waste a lot less plating solution that might normally get nowhere near the actual place you want plated and just run off the part.
Great product for the price
Very detailed
A Great item, will be back again!
These work great for details and tight nooks & crannies.
Only used one of these so far but found the tool excellent for reaching into tight spots where the regular wand just won't go.
fine is the point
These wands work great on detailing small areas on jewelry
excellent
Worked very well.
works well
Am happy with them worth there money
