Flash Copper Solution Part B - 1 Pint
Hazardous Shipping Info
SDS
Kits may contain more SDS than listed here. Contact us for details
great value in a small quantity!!!
Not only dose this make it afordable to upgrade my flash kit it also can be used to make up some brush plating solution! Caswell makes it more than simple to plate just about anything...caveman simple
