Caswell Science Plating Kit - Flash Copper Plating
Teach The Science Of Electroplating
Caswell Science Plating Kits
Flash Copper Plating System
Electroplating is an interesting and exciting science experiment for kids and adults alike. Invented in the early 1800's, electroplating covers science fundamentals such as chemistry, electricity and mathematics.
Our Science Plating Kits support NGSS standards at the Grade Five level in the "Matter and Its Interactions" topic, as well as many others.
Our Flash Copper Science Plating Kit can be used to plate copper over steel, zinc, pot metal, stainless steel, nickel, tin, gold, silver, brass, copper and bronze.
Our FlashCopper Science Plating Kit contains:
- 1 x One Pint Plastic Beaker
- One Pint Flash Copper Plating Solution
- Two Copper Anodes
- 4.5V, 300ma DC Power Supply
- All required wires
- Wooden Tank Bar
- Bare Copper Wire To Hang Parts
- Instruction Sheet
In addition to our kit, you will need:
- Nitrile or Latex Gloves
- Eye Protection
- Beaker of Water for rinsing
- Cleaning agent (we recommend dish soap and hot water or Simple Green cleaner)
The kit can be used multiple times. The anodes will eventually be used up (after approx 10 sq ft of plating), and can be replaced.
The Flash Copper Plating Solution is a mild alkali and is quite safe to use. No fume control or face masks are required for use.
SDS will be sent with the kit.
GHS Info
SDS
