Caswell Science Plating Kit - Gold Plating
Teach The Science Of Electroplating
Caswell Science Plating Kits
Gold Plating System
Electroplating is an interesting and exciting science experiment for kids and adults alike. Invented in the early 1800's, electroplating covers science fundamentals such as chemistry, electricity and mathematics.
Our Science Plating Kits support NGSS standards at the Grade Five level in the "Matter and Its Interactions" topic, as well as many others.
Our Gold Science Plating Kit can be used to plate gold over nickel, copper, brass, silver and tin.
Our Gold Science Plating Kit contains:
- 1 x One Pint Plastic Beaker
- One Pint Gold Plating Solution
- Two Stainless Anodes
- 4.5V, 300ma DC Power Supply
- All required wires
- Wooden Tank Bar
- Bare Copper Wire To Hang Parts
- Instruction Sheet
In addition to our kit, you will need:
- Nitrile or Latex Gloves
- Eye Protection
- Beaker of Water for rinsing
- Cleaning agent (we recommend dish soap and hot water or Simple Green cleaner)
The kit can be used multiple times. The gold is depleted from the solution. Additions can be made to replenish.
The Gold Plating Solution does not contain any hazardous components and is quite safe to use. No fume control or face masks are required for use.
SDS will be sent with the kit.
GHS Info
SDS
