SUPER STRIPPER POWDER COATING REMOVER - 1 Gallon
- Performs at room temperature
- Fast Acting and Long Lasting
- Non-Flammable
- No Ozone Depleting Chemicals
- No Air Pollution Potential
Caswell Super Stripper is compatible with most metals and plastics. It safely removes powder coatings from galvanized steel, aluminum, zinc, copper, brass, carbon steel and stainless, as well as most plastics, but not silicones.
Stripping time ranges from 30 - 120 minutes, depending on the thickness of the coating. The solution should be maintained above 68F.
Super Stripper reduces the coating to its powder particles, which drop to the bottom of the immersion tank. It does not require blasting, scrubbing or scraping to facilitate stripping. Agitation is recommended to minimize dissolved paint sticking to the parts.
After stripping, simply rinse off residue with water.
Keep the stripping tank covered when not in use, and filter out the solid particles occasionally to maximize service life of the solution.
One Gallon (ships in four quart bottles)
GHS Info
SDS
3 Reviews Hide Reviews Show Reviews
Excellent Product
In my business we powdercoat very small parts that must be racked. We use the Caswell Super stripper on the jigs that are parts hang on.. Works perfectly every time. Still using stripper that we bought 2 years ago.. still doing it's job. Just have to filter out the powder from the tank, and re-use the stripper over and over. Great product!
Works Great
Tried stripping a previously PC part with a HD stripper containg methylene chloride and bareley screatched the surface, part just laughed back at me. Well, after using the Caswell Super Stripper the coating just melted off within 1/2 hr. What can I say, this stuff is just awesome!
Great Item
When you need a stripper that does not rust steel then it is great for cleaning off hangers used for powder coating. Used it for many years and it does the job well.
