SHAFT ADAPTER 1/2 L.H.
These extenders are perfect for turning old electric motors into powerful buffing machines. Just attach to the shaft of your electric motor, tighten the grub screws and install the buffing wheel.
Use Right Hand Adapters For Right Side Of Buffer (Counter Clockwise Rotation) and Left Hand Adapters For Left Side Of Buffer (Clockwise Rotation)
5 Reviews Hide Reviews Show Reviews
Good product.
I must say.The product was just the way it was perceived. The shipping was fast.The product was of good quality and I would highly recommend Caswell as a place to buy.
Great for adapting a bench grinder
I bought the right and left adapters to transform a 6" bench grinder into a buffing machine. The items I received were clearly labeled; the right adapter had an "R" etched on it and the left adapter had an "L" etched on it. It was easy to install on my machine. You'll need a hex key to tighten the screws.
Excellent transaction.
I was very satified with the items that I received. Caswell's service was very responsive to my needs. Outstanding and recommended.
Thank you.
Item works as designed. Great product. Very fast shipping. Thank you for the USPS Priority Mail option! Will buy again when we need other items. Mahalo Nui Loa.
A must have for converting old motors to buffers
Adapters work perfect on my ancient 50's era Craftsman 1/2 horse motor...now I can buff my nuts off!
