null
Paints Coatings
  • ASSORTED PINSTRIPE KIT
    Pinstriping Starter Kit Six different 42 foot rolls of The Striper ® stencil tape (F-4, F-6, F-16, F-21, F-25) to match the most common pinstriping sizes. Five 4 oz. cans of Finesse Pinstriping Paint. The most popular colors. (White, Imitation Gold,...
    $95.69
    Add to Cart
  • BLACK OXIDE CONCENTRATE 1 QT
    Blackens steel and iron parts (not stainless steel). Parts must be sealed after blackening. Use our Penetrating Sealer or Caswell Sealer. Mix 1 part Concentrate with 9 parts distilled water. 1 quart of concentrate makes 2.5 gallons of blackening solution...
    $60.99
    Add to Cart
  • BOBBO/MACK SUPER QUAD #2 BOBBO/MACK SUPER QUAD #2
    BOBBO'S NEW "SUPER QUAD" 4 ACTION BRUSH(Actual Overall Length 4-1/2" - the Image is slightly larger) This is another development between Bobbo and Mack Brush Co. to bring to the pinstriper-artist a new brush to fulfill some of the difficult tasks of...
    $12.09
    Add to Cart
  • Bronze & Blackening Solution 8 fl oz Bronze & Blackening Solution 8 fl oz
    Bronze & Blackening Solution For use on Copper and Silver. Mix 1-2 fluid oz of Concentrate to 1 gal water depending on degree of effect required. Use at room temperature. Dip item into solution for 5-10 seconds, longer for darker effect. Rinse to stop...
    $27.49
    Add to Cart
  • Cerakote Micro Slick Dry Film Coating Cerakote Micro Slick Dry Film Coating
    C-110 Micro Slick is a ceramic dry film coating used to reduce friction on a variety of internal firearm components, such as bolts and bolt carriers. C-110 has a blue/grey appearance and is an air cured ceramic coating. Application Guide
    $0.00
    Out of stock
  • Cerakote Piston Coat Ceramic Thermal Barrier Cerakote Piston Coat Ceramic Thermal Barrier
    A dark brass/gold with a soft metallic finish. Piston Coat is a thin film ceramic thermal barrier, designed to be applied on internal engine parts that require a thermal barrier. Typical uses: piston tops, combustion chambers, valve tops, external...
    $0.00
    Choose Options
  • EVAPO-RUST GALLON
    EVAPO-RUST GALLON
    Evapo-Rust™ is a revolutionary new, environmentally friendly product that quickly and safely removes rust from metal objects. Removes rust in as little as 5 minutes Non-toxic, non-corrosive, safe on skin No fumes or bad odors, non-flammable, no...
    $49.00
    Add to Cart
  • HANDHELD IR THERMOMETER
    Probably the most useful tool in any powder coater's toolbox - accurate temperature readings are essential to good coatings. Curing cycles are determined by part temperature, not oven temperature, and there's no way to accurately measure part temperature...
    $84.69
    Add to Cart
  • High Temp PC Tape - 1" High Temp PC Tape - 1"
    High Temperature Masking Tape Polyimide tape is perfect for high temperature masking needs. Withstands temps up to 600F. Copper colored Maximum Temperature: 500F Total Thickness: 2 mils Excellent Electrical Insulation
    $39.04
    Add to Cart
  • High Temp PC Tape - 1/2" High Temp PC Tape - 1/2"
    $24.19
    Add to Cart
  • High Temp PC Tape - 2" High Temp PC Tape - 2"
    $77.54
    Add to Cart
  • IRON PHOSPHATE PRIMER - 1 GALLON
    Increase the corrosion resistance of your powder coated parts. Caswell Iron Phosphate Primer is a concentrated liquid, multiple temperature, detergent iron phosphate. It provides metal surfaces with a unique underpaint corrosion resistance and prepares...
    $70.39
    Add to Cart
  • IRON PHOSPHATE PRIMER - 1 PINT
    $27.49
    Add to Cart
  • KELLY/MACK STRIPER SET
    Kelly-Mack Striper Set Tom Kelly's grandfather, O.Z. Crozier, (aka) "The Baron" of Baron Roth & Kelly started striping wagons & buggies for the Studebaker Bros. in the early 1900's. He then striped at the Ford Motor Co. for over 25 years through the...
    $40.14
    Add to Cart
