Quick view Polymeric sku: AQUA5 AQUAMEND EPOXY MSRP: Now: $9.48 Out of stock Compare Quick view Polymeric sku: FASTST5 FASTSTEEL EPOXY MSRP: Now: $9.48 Add to Cart Compare Quick view Polymeric sku: QUIKWP3 QUIKWOOD EPOXY PINE MSRP: Now: $6.95 Out of stock Compare Quick view Polymeric sku: REPQ5 REPAIRITQUIK EPOXY PUTTY - 4OZ MSRP: Now: $9.48 Add to Cart Compare Quick view AQUAMEND EPOXY "No Boat Should be Without it" After proper mixing, AQUAMEND® molds like clay and may be used to patch dings, scratches, cuts, gouges, and holes in fiberglass, metal, and wooden boat decks and hulls; to repair fittings, pipes, electrical connections,... MSRP: Now: $9.48 Out of stock Compare Quick view FASTSTEEL EPOXY "Don't weld it, FASTSTEEL it!" FASTSTEEL® is a hard kneadable, steel-reinforced, epoxy putty adhesive sealant that mixes in just one minute to provide fast repairs to items made of ferrous and aluminum metals. it comes in a handy four-ounce... MSRP: Now: $9.48 Add to Cart Compare Quick view QUIKWOOD EPOXY PINE "The Woodworker's Dream" Repair, Rebuild, Restore Anything Made of Wood QUIKWOOD® is a remarkable polymer compound for instant wood repair. Easy-to-use QUIKWOOD® molds like clay, then dries like wood in 30 minutes. QUIKWOOD® is also great for... MSRP: Now: $6.95 Out of stock Compare Quick view REPAIRITQUIK EPOXY PUTTY - 4OZ Repair loose or cracked wall, floor tiles Electrical use in place of tape or plastic connector Fabricate small parts, mend holes Attach fixtures, machines, tags and signs Use for 1001 Household and Industrial purposes REPAIRITQUIK® is a hand... MSRP: Now: $9.48 Add to Cart Compare Compare Selected × OK
