The great new way to brush plate small parts
Video: Title
Using The Caswell Plug N Plate Brush Plating Kit
Read An Article From Mac Life Magazine On Plating An iPod Using Our Plug N' Plate® Kits (372 KB PDF)
Read the Instruction Manual Here
4 Simple Steps To Brush Plate Your Small Parts
1. Plug In The Adapter | ![]() |
2. Clip the Black Lead To The Part | ![]() |
3. Soak The Wand With Bandage In the Solution | ![]() |
4. Brush The Wand Over The Cleaned Part | ![]() |
Plug N' Plate® is a new concept in plating small parts. Our unique mains power pack supplies just the right amount of power allowing you to brush, and in some situations, dip plate your smaller components.
The Plug N' Plate® system will also allow you to patch repair areas where the original plating has worn away.
Plug N' Plate® is ideal for vintage vehicle restorers, antique collectors and dealers, and small workshops doing prototype work.
What could be simpler? The Plug N' Plate® wand is attached to the red plug on the Power Pack, and the alligator clip is attached to the work-piece. The end of the wand is covered in an absorbent bandage, which is soaked in the plating solution for a few seconds.
By simply stroking the part with swift brush strokes, the circuit is closed and the plating metal bearing solution goes to work, depositing its beautiful layer onto the object.
Plug N' Plate® is perfect for gold plating car emblems. Simply strip the chrome off with Chrome Stripper, then apply the gold. Full instructions are included.
Plug N' Plate® may be applied onto most metals. To see which kit plates onto which metal, read our instruction booklet. To plate onto Stainless Steel, use the Plug N' Plate® Copper system. When gold plating onto stainless, apply our Stainless Steel Activator For Gold with a stainless wand and 4.5V power pack, then you may gold plate directly onto the stainless part.
Aluminum can be plated with the Acid Copper Plug N Plate system, after prepping your part with Zincate.
Plastic parts can also be plated with our Acid Copper Plug N Plate system after painting with conductive paint and swabbed with Tinning Solution.
* - Manufacturer Direct Pricing. Plug N' Plate® is a registered trademark of Caswell Inc.
Plug N Plate Nickel/Copper Kit Contains:
- 1 x Plug N' Plate® 4.5V Power Supply
- 1 x 8oz Nickel Solution
- 1 x 8oz Flash Copper Solution
- 1 x SS Brush Plating Wand
- 1 x Copper Brush Plating Wand
- 2 x Wand Bandage
- 1 x Instruction Booklet
- Free Technical Support
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
GHS Info
SDS
13 Reviews Hide Reviews Show Reviews
worked perfectly to build up material
Nice kit. Compact and easy to use. I was able to apply plenty of material with issues. Easy to polish up.
work great
excellent product
Excellent Starter Kit for Copper and Nickel
This is an excellent kit for getting started. By ordering more Nickel plating solution, I was also able to use the kit to immerse larger pieces in a small bowl and plate the entire object.
copper nickel plug n plate kit
great kit. I did a post 64 Winchester receiver m94 because those receivers won`t take bluing. lots of polishing and cleaning with denatured alcohol. had to heat the nickel fluid for it to work good. after that everything was great. the gun looks professionally done. they wanted 500 dollars to do it and I did it for less than 100 in my basement.
Works Great!!!!
Have a small fly rod building company, used the brush plating systems to fix old and plate new reel seats, plated snake guides and checks! Was very surprised and excited with results!!! I am ordering more solutions and kits right now!
WORKS PERFECTLY
DOES A GREAT JOB
WORKS PERFECTLY
DOES A GREAT JOB
Very easy to use
Delivered at 3:30 pm and I was plating at 5:20. Most of the time was prep. Granted I was just goofing around with stuff but the results were great. I'll be doing some detail work on the antique and classic cars the kit is perfect for small items
great
I enjoy using this product.
