Permlac Transparent Tints
Permalac Original, and Permalac NT can also be tinted with our line of translucent tints. These tints come in 7 colors: gold, copper, yellow, red, black, violet, and blue. These tints are colorfast, will not fade, and can be mixed to make a custom patina. Tints can be mixed between 1:15 (tint to lacquer) and 1:30 ratios to yield the best results.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
Recommended Skill Level
![Beginner](/images/stencil/original/image-manager/beginner.png)
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
SDS
