We have added some transparent/translucent colors to our Permalac line that are meant to be applied over light colored steel or metal for special effects. These products still offer the 5/8 years of protection against corrosion on all steel & metals that our Permalac Clear Coats offer:
For light colored steel & metal
Permalac NT Brass: will make light colored metal resemble Antique Brass
Permalac NT Bronze: will make light colored metal resemble Antique Bronze
Permalac NT Christmas Gold: A Dark Gold color that resembles a deep Gold color
Permalac NT Rose Gold: A transparent tint that is a Reddish Gold color
                Recommended Skill Level
                    Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
Hazardous Shipping Info
GHS Info
SDS
