STRIP OUR GAS TANK SEALER COATING FROM METAL TANKS
NON METHYLENE CHLORIDE FORMULA MEANS SAFER USAGE AND AVAILABILITY TO ALL CUSTOMERS
NOT FOR USE IN FIBERGLASS OR PLASTIC TANKS (unless it is used extremely carefully with constant monitoring. Product will dissolve gel coat and plastics)
- Use AS IS at room temperature, or dilute with up to 50% water and heat to 150F.
- Strip time is 2 hours to overnight, depending on the thickness of the coating
- Agitation in the tank will decrease overall time
![This product cannot ship by air or outside the USA Lower 48 States. Ground Shipping Only This product cannot ship by air outside the USA Lower 48 States. Ground Shipping Only](/content/images/noair.png)
Hazardous Shipping Info
![](/content/images/corrosive.gif)
GHS Info
![](/content/images/ghs_corrosive.jpg)
![](/content/images/ghs_harm.png)
