Mix 3.5 qts of distilled water and 2 qts of battery acid, then add 1 Quart concentrate and 1 Pint activator.
Makes 1.75 gallons. CAUTION: Add acid to water, not water to acid.
![This product cannot ship by air or outside the USA Lower 48 States. Ground Shipping Only This product cannot ship by air outside the USA Lower 48 States. Ground Shipping Only](/content/images/noair.png)
Hazardous Shipping Info
![](/content/images/corrosive.gif)
GHS Info
![](/content/images/ghs_carc.jpg)
![](/content/images/ghs_toxic.jpg)
![](/content/images/ghs_corrosive.jpg)
![](/content/images/ghs_harm.png)
SDS
Kits may contain more SDS than listed here. Contact us for details
