Electroless Tin Plating Kit
Tin Plate Copper, Brass, Gold and Copper Based Alloys Without Power Or Heat!
Simple to use. Plates tin over copper, brass, gold and copper based alloys in seconds! No power required.
Degrease your parts and hang them into the solution from string or copper wire. Immerse in the 120F solution for 60 seconds to put a bright tin plating onto the base metal.
It couldn't be simpler!
Perfect for tin plating circuit boards, or retinning cookware.
Plates at 1/1000" per 15 mins. Bath life is approx 100 sq ft per gallon at 0.000025" thicknes.
Contains Hydrochloric Acid.
3 Gallon Kit Contains:
- 1 x 3.5 Gal Plating Tank & Lid
- 3 Gallons Electroless Tin Solution
- Instructions
- Free Technical Support
- NO HEATERS INCLUDED
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Hazardous Shipping Info
GHS Info
SDS
