null
Additional Items Required
Get Our Plating Manual
Plating Kits
  • 3D Printed Parts Plating Kit 3D Printed Parts Plating Kit
    Plate 3D Printed Parts Easily Plates over PLA, ABS, PVA, Nylon and More Includes Highly Conductive Graphite Bearing Paint Easily Create Professional Looking Metallic Parts At Home Plates A Bright, Smooth Copper Plated Finish. Professional Grade Plating...
    $273.90
    Choose Options
  • 4.0 PH BUFFER SOLUTION
    DIGITAL PH TESTER FOR PLATING SOLUTIONS Accurately measures pH ranging from 0-14 pH. Pocket-sized, lightweight instrument will quickly test all your plating solutions, and even your swimming pool water. The unit is splash-proof, and has one point...
    $6.59
    Add to Cart
  • 5 AMP CC RECTIFIER
    5 Amp Constant Current Rectifier Ideal for small anodizing runs, small plating jobs. Will anodize parts up to 1 sq ft. Will nickel & copper plate parts up to 70 sq in.   Other options: Wamptek Dr Meter Hanmatek
    $213.40
    Add to Cart
  • 7.0 PH BUFFER SOLUTION
    $6.59
    Add to Cart
  • Aluminum Brightener
    Aluminum Brightener
    Cleans and brightens aluminum, stainless steel, copper, brass, and non-ferrous metals. In just seconds, the industrial strength formula dissolves grease, oil stains, grime and road film. Dilute 4-6 oz per gallon of water depending on the cleaning job...
    $40.69
    Add to Cart
  • Aluminum Degreaser Powder - 10 lb Makes 15 Gallons
    This special degreaser for Aluminum quickly cleans any aluminum alloy without etching. Mix 10 lbs of cleaner with 15 gallons of distilled water in a stainless steel container. Heat to 130 deg F on a hotplate. Immerse aluminum parts for 3-10 minutes prior...
    $133.09
    Add to Cart
  • Aluminum Degreaser Powder - 2lb Makes 3 Gallons
    This special degreaser for Aluminum quickly cleans any aluminum alloy without etching. Mix 2 lbs of cleaner with 3 gallons of distilled water in a stainless steel container. Heat to 130 deg F on a hotplate. Immerse aluminum parts for 3-10 minutes prior...
    $30.24
    Add to Cart
  • ANODIZE & CHROME  STRIPPER - 8 OZ
    8 fl oz of stripping solution. To strip anodize, immerse parts for 5-30 minutes. To strip chrome, use a stainless steel wand and 12V DC. Contains Hazardous Goods. Shipping restrictions apply. Ground shipping only to the Continental USA. Please call +1...
    $7.69
    Add to Cart
  • B9 NICKEL STRIPPER - 2.5 LB
    NO ELECTRICITYNO CYANIDESNO PHOSPHATESNO CAUSTIC AMINESNO AMMONIANO FUMES The only one-component, non-toxic, powdered, immersion nickel strippers on the market. Removes NICKEL from steel, copper, brass and zinc diecast, silver and gold. Caswell Inc...
    $32.99
    Add to Cart
  • B9 NICKEL STRIPPER - 5 LB
    NO ELECTRICITYNO CYANIDESNO PHOSPHATESNO CAUSTIC AMINESNO AMMONIANO FUMES   The only one-component, non-toxic, powdered, immersion nickel strippers on the market. Removes NICKEL from steel, copper, brass and zinc diecast, silver and gold. Caswell...
    $52.24
    Add to Cart
  • B913 NICKEL STRIPPER FOR ALUMINUM 2.5 LB
    $32.99
    Add to Cart
