Caswell Mega Black™ Blackening Kit
Can Be Shipped Worldwide and by Air
Room Temperature Blackening Of Steel
No Dangerous Fumes Or Corrosive Chemicals
![](https://cdn11.bigcommerce.com/s-h3iiojmd0h/product_images/uploaded_images/ww.png?t=1622056262)
Our NEW Caswell Mega Black™ is the most advanced blackening system for steel on the market today. It produces a darker finish than our standard Black Oxide process and can be shipped worldwide without Dangerous Goods fees.
Mega Black™ works on cold and hot rolled carbon steels, alloy steels, tool steels, as well as cast iron, forged steels and powdered metal...even A2 tool steel.
It does not work on Stainless Steel.
Parts to be blackened must be clean and free of rust or scale. Our SP-Degreaser can be used as a cleaner. Our Pickle #4 can be used to remove rust and scale.
Steps to Blacken parts:
- Remove rust and clean parts thoroughly. Never use cleaners like lacquer thinner or alcohol. Only use detergent based cleaners, like our SP-Degreaser. Perform a water break test.
- Mix the Mega Black™ concentrate at 10% with distilled water. 1 pint of Mega Black™ makes 1.125 gallons of blackening solution
- Immerse for 2-3 minutes, to a maximum of 5 minutes
- Rinse in distilled water then seal with our Caswell Sealer, a water based acrylic sealer.
Kits Include:
- Caswell Mega-Black™ Concentrate
- Caswell Sealer - water based acrylic sealer
- 2 x HDPE Plastic Tanks & Lids
- Instructions
Caswell Mega Black™ can also be brushed or swabbed on. It can be used at full strength, 50% for a slower reaction or at the standard 10% strength. We recommend testing on some sample pieces to determine the best reaction time and mix for your project.
Coverage is approx 300 square feet per gallon of concentrate when used in an immersion setup.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
Recommended Skill Level
![Beginner](/images/stencil/original/image-manager/beginner.png)
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
GHS Info
![](/content/images/ghs_toxic.jpg)
SDS
