Quick view Gemtex sku: GEM25130923 Surface Prep Disk 3" Fine MSRP: Now: $2.52 Add to Cart Compare Quick view Gemtex sku: GEM25130903 Surface Prep Disk 3" Medium MSRP: Now: $2.52 Add to Cart Compare Quick view Gemtex sku: GEM25130953 Surface Prep Disk 3" Very Fine MSRP: Now: $2.52 Add to Cart Compare Quick view Caswell sku: BLUBGKT Tailpipe Polishing Kit MSRP: Now: $36.67 Add to Cart Compare Quick view Formax sku: F515-6061 TALLOW BASED GREASE STICK GRADE F-10 MSRP: Now: $13.27 Add to Cart Compare Quick view Formax sku: F515-6064 TALLOW BASED GREASE STICK GRADE F-17 MSRP: Now: $13.27 Add to Cart Compare Quick view Caswell sku: TB2 TAPERED BUFF MSRP: Now: $13.27 Add to Cart Compare Quick view Caswell sku: BTL4B TAPERED BUFFING SPINDLE 1/2" LEFT MSRP: Now: $22.76 Add to Cart Compare Quick view Caswell sku: BTR4B TAPERED BUFFING SPINDLE 1/2" RIGHT MSRP: Now: $22.76 Add to Cart Compare Quick view Caswell sku: BTL5B TAPERED BUFFING SPINDLE 5/8" LEFT MSRP: Now: $22.76 Add to Cart Compare Quick view Caswell sku: BTR5B TAPERED BUFFING SPINDLE 5/8" RIGHT MSRP: Now: $22.76 Add to Cart Compare Quick view Caswell sku: CR-8 TAPERED THREAD MANDREL MSRP: Now: $6.31 Add to Cart Compare Quick view Caswell sku: RZ6 TREATED RAZOR BUFF - 6" MSRP: Now: $5.68 Add to Cart Compare Quick view Caswell sku: RZ8 TREATED RAZOR BUFF - 8" MSRP: Now: $6.95 Add to Cart Compare Quick view Caswell sku: DC4 TREATED SPIRAL SEWN BUFFING WHEEL - 4 MSRP: Now: $9.99 Choose Options Compare Quick view Surface Prep Disk 3" Fine Surface Preparation Quick Change Abrasive Disks Ideal for paint and light rust removal Uses the same sanding pad and arbor as the Aluminum Oxide Sanding Disks MSRP: Now: $2.52 Add to Cart Compare Quick view Surface Prep Disk 3" Medium Surface Preparation Quick Change Abrasive Disks Ideal for paint and light rust removal Uses the same sanding pad and arbor as the Aluminum Oxide Sanding Disks MSRP: Now: $2.52 Add to Cart Compare Quick view Surface Prep Disk 3" Very Fine Surface Preparation Quick Change Abrasive Disks Ideal for paint and light rust removal Uses the same sanding pad and arbor as the Aluminum Oxide Sanding Disks MSRP: Now: $2.52 Add to Cart Compare Quick view Tailpipe Polishing Kit Removes Heat Blue Stain From Chrome Finishes Tired of using powders that need to be mixed with water? Tired of silly little amounts of product for high prices? Tired of all the hard work rubbing the pipes? Then the BLUE BEGONE™ SYSTEM is for you! We... MSRP: Now: $36.67 Add to Cart Compare Quick view TALLOW BASED GREASE STICK GRADE F-10 A medium priced white grease stick with good lubricating qualities. Our most popular grade for average polishing use. MSRP: Now: $13.27 Add to Cart Compare Quick view TALLOW BASED GREASE STICK GRADE F-17 A firm, hard yellow grease stick suitable for heavy-duty polishing wheel operations. A popular grade. MSRP: Now: $13.27 Add to Cart Compare Quick view TAPERED BUFF 2" Diameter x 2" Long 1/4" Shaft MSRP: Now: $13.27 Add to Cart Compare Quick view TAPERED BUFFING SPINDLE 1/2" LEFT Tapered Buffing Spindles are ideal for mounting buffing wheels with pinhole centers, such as our Razor Buff. Simply attach the spindle onto your 1/2" or 5/8" shaft, tighten the grub screws, and the spin the motor up. The buffing wheel is pushed onto the... MSRP: Now: $22.76 Add to Cart Compare Quick view TAPERED BUFFING SPINDLE 1/2" RIGHT Tapered Buffing Spindles are ideal for mounting buffing wheels with pinhole centers, such as our Razor Buff. Simply attach the spindle onto your 1/2" or 5/8" shaft, tighten the grub screws, and the spin the motor up. The buffing wheel is pushed onto the... MSRP: Now: $22.76 Add to Cart Compare Quick view TAPERED BUFFING SPINDLE 5/8" LEFT Tapered Buffing Spindles are ideal for mounting buffing wheels with pinhole centers, such as our Razor Buff. Simply attach the spindle onto your 1/2" or 5/8" shaft, tighten the grub screws, and the spin the motor up. The buffing wheel is pushed onto the... MSRP: Now: $22.76 Add to Cart Compare Quick view TAPERED BUFFING SPINDLE 5/8" RIGHT Tapered Buffing Spindles are ideal for mounting buffing wheels with pinhole centers, such as our Razor Buff. Simply attach the spindle onto your 1/2" or 5/8" shaft, tighten the grub screws, and the spin the motor up. The buffing wheel is pushed onto the... MSRP: Now: $22.76 Add to Cart Compare Quick view TAPERED THREAD MANDREL Tapered Cartridge Roll Mandrel 1/4" x 2.5" MSRP: Now: $6.31 Add to Cart Compare Quick view TREATED RAZOR BUFF - 6" 1/8" thick treated, razor buffs are perfect for getting into tight work areas and between fins on cylinder heads. The treated material is tough, long lasting and flexible. Use with a cutting compound. Buffs feature leather reinforced centers, with half... MSRP: Now: $5.68 Add to Cart Compare Quick view TREATED RAZOR BUFF - 8" 1/8" thick treated, razor buffs are perfect for getting into tight work areas and between fins on cylinder heads. The treated material is tough, long lasting and flexible. Use with a cutting compound. Buffs feature leather reinforced centers, with... MSRP: Now: $6.95 Add to Cart Compare Quick view TREATED SPIRAL SEWN BUFFING WHEEL - 4 These buffs are specially treated to give longer life than standard buffs. This treatment makes them much harder than regular cotton buffs, which allows the user to exert more pressure onto the wheel and gets the job done faster. Use with any compound... MSRP: Now: $9.99 Choose Options Compare Previous 16 17 18 19 20 21 22 23 Next Previous 16 17 18 19 20 21 22 23 Next Compare Selected × OK
