This 16" 2-Speed buffer provides fast and effective deburring, finishing, graining, surface conditioning, polishing and buffing. It can easily remove scratches and imperfections, bringing out the natural luster of the metal. Designed to run convolute wheels, wire wheels, flap wheels, nylon wheels, fiber or bristle-brush wheels as well as buffing and polishing wheels. This buffer / polishing lathe will handle the most demanding polishing applications as well as fine detailing work.
- Direct drive power train with rugged oversized threaded nickel chromed shaft
- Production duty 2 speed motor
- Reliable oversized ball bearings, fully shrouded and sealed for extended life
- Plenty of room between the wheels to accommodate a wide variety of parts simply and quickly
- Versatility is enhanced by narrow and wide wheel capability with a wheel clamping range that allows the mixing and matching from narrow to wide wheels of different sizes and types
- Set of wheel spacers and washers
- Cleanliness maximized by floor stand wheel covers with adjustable eye guards
- Safety eye guards
- Safety electrical system, white power on light, green machine running light, 2-speed hi/low drum switch, on/off power push button power switch with keyed lock-out, emergency stop push button with electronic brake and 24 volts at all switches
- Heavy duty steel floor stand with hinged door, internal storage and anti-vibration foot pads
- 7.5 Horsepower
- 230V, 18.6 amps
- Motor Speed (RPM): 1750 & 3500
- Disk Speed (SFPM): 7175 & 14355
- Arbor Size: 1-3/8"
- Wheel Thickness Stack: 1 in, 1.5 in, 3.5 in
- Weight: 585 lbs
DIMENSIONS: - 67" L x 21.25" W x 47.25" H
SHIPS LTL FREIGHT
