White Wall Masking Tape - 1/4" Wide x 36 Yards Long Blue Vinyl
This specially designed, extra thin, vinyl masking tape is perfect for use with our White Wall Paint.
The extra thin width and flexibility of the vinyl material provides for perfect masking on curved edges, allowing you to create a perfect circle around your tire.
