White Wall Tire Paint 250ml Can, 8.5 fl oz
Add White Walls onto any tire with our new White Wall Tire Paint
White Wall Tires hard to find? Many sizes are no longer made or very expensive. Get that classic look for your car or bike - from a can!
Whitewall Tire Paint is a specially formulated rubberized paint with excellent bonds to most types of tires.
Costs only a few dollars per tire.
Perfect for all cross-ply tires and most radials.
Water-based formula is easy to apply and clean up.
Application is easy
Lightly sand off any embossed lettering with 180 grit discs, then buff smooth with 400 grit.
Wipe down the area with naphtha or paint thinner.
If you need to mask, use a very narrow tape to easy application to the curve.
Using a soft bristled brush or sponge brush, apply 4 coats, leaving 4 hours between coats.
SDS
Videos Hide Videos Show Videos
Great product - prep work can be difficult
I started working with the 6" orbital sander on the sidewalls of the Dextero's on my 47' Diamond T Dually... It didn't touch the heavy lettering... The lettering was quite thick. I hit it with the grinder and a flap disk... the lettering started coming off and spewing molten rubber chunks everywhere.... my shop looks like the wheel well of our 24 Hour of Lemons car after a Texas Race in August.... Got all the heavy duty lettering and sidewall decorations off, but had an absolute mess to clean up... I pulled out the cans of brake cleaner and a razor blade... I worked around the tires scooping off rubber boogers... After initial cleaning, I worked around the tires with the orbital, and following it up with another razor/brake cleaner scraping. I think the preparations worked pretty well, but I still gotta clean the rubber boogers off the rims. I also used a little water in the last couple coats to get it smoothed out...
