15 Gal Triple Chrome Plating Kit
Kit comes with rectangular tanks 12W x 24L x 18H
Watch How To Use This System - Full DVD Included In Kit
| This kit has been especially designed for the smaller workshop requiring high quality Chrome plating facilities for small to medium sized parts. It is ideally suited to operate as a small business venture, plating automotive and motorcycle parts. The kit is supplied with 2 rectifiers, the smaller one, a 25 amp capacity, is designed to operate the copper and nickel plating tanks, with a maximum capacity of approx 300 sq. inch surface area. Amperage requirements for copper and nickel plating are approximately 1 amp per 15 square inches of surface area. | ![]() |
| The larger rectifier, supplied by Aldonex Inc, is a 250 amp capacity, specifically designed to control the higher demands of the Chrome Plating tank. | ![]() |
Amperage requirements of chrome plating are 1+ amps per square inch of surface area.
The 6 tanks supplied are constructed of HDPE, a chemical resistant plastic. They come with a lid to ensure tanks are completely safe and sealed when not in use. Dimensions are:- 12W X 24L X 18H
The Kit Contains:-
- 1 x 250 Amp Rectifer
- 1 x 25 Amp Rectifier
- 6 x 20 gal Plastic Plating tanks withlids
- 2 x 18" x 20" Nickel Anodes and bandages
- 2 x 18" x 20" Copper Anodes and bandages
- 4 x 12" x 12" GP Plates
- 4 x 12" x 12" Chrome Anodes
- 10 Packs Nickel Crystals with Brightener (Makes 15 Gals)
- 10 Packs Copper Crystals (Makes 15 Gals)
- 10 x 1.5oz Copper Brightener A
- 3 x 4oz Copper Brightener Part B
- 10 Cans Chrome Crystals with Catalyst (Makes 15 Gals)
- Flash Copper™ Part A - 20 Quarts
- Flash Copper™ Part B - 5 Quarts
- Flash Copper™ Part C - 5 Quarts
- SP Degreaser 8 lb (makes 16 gals)
- 6 Filter/Agitator Pumps (2 Each For Nickel, Copper & Flash Copper™ systems)
- The Caswell Plating Manual
- How To Video/DVD
- Fume Control Balls
Rectifiers have a 1 year limited warranty.
Not available to residents of California unless an appropriate permit has been obtained. Use Reprochrome® instead.
Recommended Skill Level
Advanced level products require multiple steps to achieve end results, such as conductive paints, or multiple cleaning steps. While many novice customers have used these products successfully in the past, we recommend some experience using easier processes before trying an advanced level product.
Hazardous Shipping Info
GHS Info
SDS
Videos Hide Videos Show Videos
