with Copy Chrome™ a Cobalt/Chrome Look Alike. Allows use of a smaller power supply and much safer to use than Real Chrome.
Watch How To Use This System - Full DVD Included In Kit
NOW INCLUDES ZINCATE AND ALUMINUM DEOXIDIZER FOR A COMPLETE ALUMINUM PLATING SOLUTION
A revolution in real decorative chrome plating; this new kit has special additives which widen the operating range of the system, making the system much easier for the novice to control. A small amount of battery acid is required for the copper system.
This 3 step chrome plating kit has been designed to provide a show quality nickel, copper & chrome plate on items such as headlights, bezels, bumperettes, nuts & bolts, brackets, etc. It can be applied to copper, steel, brass, aluminum, lead, pewter and zinc die cast substrates.
There are three different processes, each with its own tank & chemicals, as well as the cleaning, zincating and deoxidizing tanks. The chrome plate is always applied over a nickel plate, which will fuse to most metals quite readily. The acid copper plating system is used as a hi-build filler to cover blemishes, pits and scratches. The copper plate can be built up to thicknesses of 1/8", and Casweld™ can be used to fill in deeper pits. The solder and plate is then sanded/polished and re-plated before nickel plating. This is an invaluable tool for the restorer!
Now, with the addition of Flash Copper™ to this kit, you can plate onto Pot Metal without having to buy additional kits. Pot Metal parts are plated first with Flash Copper™. They may then be built up with the regular Copper system if desired, then nickel and chrome plated.
The included Pickle #4 solution lets you plate onto lead and pewter easily. After immersing in Pickle #4, you should plate with Flash Copper™.
Aluminum parts must be dipped in Zincate and Deoxidizer (included) solution prior to Flash Copper plating.
Lead/Pewter parts must be dipped in Pickle#4 (included) prior to Flash Copper plating.
The kit contains:
- 8 x 2 Gal Plating tanks with lids
- 2 x 6" x 8" Nickel anodes & bandages
- 2 x 4" x 8 Copper anodes & bandages
- 2 x 6" x 6" Cobalt Anodes
- 2 x 8" x 8" GP Plates
- 1 Pack Nickel Crystals w/Brightener (Makes 1.5 Gals)
- 1 Pack Copper Crystals (Makes 1.5 Gals)
- 1 x 1.5oz Copper Brightener A
- 1 x 4oz Copper Brightener B
- 1 Pack Copy Chrome™Crystals w/Brightener (Makes 1.5 Gals)
- 1 x 1.5 gal Flash Copper™ Chemicals (A, B, C)
- 1 Pack SP Degreaser (Makes 4 Gals)
- 1 Qt Aluminum Deoxidizer (Makes 2 Gals)
- 1 Qt Zincate (Makes 1 Gal)
- 4 x Filter/pumps
- 1 Pack Pickle #4 (Makes 2 Gals)
- The Caswell Plating Manual
- How To DVD
- Free Technical Support
- NO HEATERS INCLUDED
![]() Cam Chain Tensioner Chrome Plated With This Kit By James Bateman | ![]() Kickstart Chrome Plated With This Kit By James Bateman | ![]() Engine Cover Plated With This Kit By James Bateman |
The nickel plating system will readily accept the final layer of chrome plate. The power source may be either a 6v or 12v battery or charger or a rectifier. (Get help choosing the correct rectifier)
Nickel plating process will take approx 30-60 minutes. Copper plate operation will take from 10 minutes to several hours if building up thick layers. The final Copy Chrome plate layer takes only 4 minutes. Nickel & copper kits will plate approx. 60 square feet of surface area, before the anodes need replacing. Nickel & Copper plating require 1 amp per 16 square inches of your part.
The final Copy Chrome™ step requires 1 amp per 32 sq inches and plates a brilliant chrome-like finish in 15-30 minutes.
There are no cyanides in these systems.
Recommended Skill Level
Advanced level products require multiple steps to achieve end results, such as conductive paints, or multiple cleaning steps. While many novice customers have used these products successfully in the past, we recommend some experience using easier processes before trying an advanced level product.
Hazardous Shipping Info
GHS Info
SDS
