Spray On Chroming System - 25-50 square feet
Our PChrome Spray Chrome Starter Kit is the ideal spray chrome kit for interior and exterior designers, hobbyists and artists. Express your creativity on almost any surface such as wood, metal, plastic, concrete, or anything else that can be painted.
You can reproduce a chrome look on nearly any substrate, right at home, in your workshop, or garage and without the need for a compressor. PChrome gives 100% of the gleam at about 25% of the cost. Available in silver, black, red, copper, blue or gold tone.
PChrome is perfect for:
- Small DIY Shops
- Auto Restorers
- Artists
- Crafts
- Designers
- Hobbyists
- Model Cars, trucks, trains, planes
- RC Cars, trucks, planes, boats, drones
- Gamers, and more
There are several reasons why PChrome spray is a superior choice over both chrome spray paint and traditional chrome plating, including:
- Much more durable than spray paint
- Gives the same brilliant shine as chrome plating
- Can be used on parts of any size
- Is available in a variety of different hues
- Can be applied on-site
- Substantial time and cost savings
- Thicker coatings
- Lesser environmental impact
- Doesn’t require hazardous acid baths
What's in the Spray Chrome Kit?
Included in this kit your will find the following equipment and materials:
1) Double bottle sprayer for simultaneous application of PChrome S and PChrome R solutions
2) Three single bottle sprayers. These bottles are used for applying the PChrome D, W, and rinse water. Each bottle is pre marked with the chemical it should hold.
3) Measuring Cups and pipettes. Use these to measure your chemicals. Do not cross contaminate! Each cup should be used for only one type of chemical.
4) One powered paint spraying kit. Use for applying your basecoat and top coat.
5) 2 oz PChrome S, 2 oz PChrome R, 2 oz PChrome D, 2 oz #87 4 oz PChrome W, 1 pint Permalac 2KA, 1 pint Permalac 2KB, 1 oz compensating tint. All the material you need to create 50 square feet of PChrome.
Compared to chrome, PChrome is:
- Durability equal to traditional chrome
- Bonds to the substrate as well as traditional plating
- Highly resistant to weather, salt and abrasions
- Equally reflective
- A greener choice over plating
- Low outlay of capital
- No size or part limitations
- Able to be used on-site
- Fewer steps in the process
- Thicker coatings
- Choice of materials
- Faster turnaround times
- Safer and healthier to use
Download Instructions Here
Videos Hide Videos Show Videos
