PLASTIC-GLO (ULTRA FINE DRY GRADE)
PLASTIC BUFFING WHEEL BAR COMPOUNDS
FOR USE ON: PLASTIC, HARD RUBBER, CELLULOID
Use as a first step when polishing plastic, acrylic, wood and lacquered finishes.
10 Reviews Hide Reviews Show Reviews
Best plastic finishes
I've tried a variety of compounds for the final finish on pen parts and so far this is it. You've got to be at the right starting point, but when you're just about finished, use this compound and your final plastic product will absolutely come to life!
more
more than what I thought it would be, should last me a very long time
These sticks are HUGE!
Appears to be a lifetime supply.
Great Product as always
excellent final buff stainless steel
I use for Stainless Steel
the bar really works well for a final buff with cotton wheel on stainless steel...Great Product ... Thanks
Great pre finish buff.
I use this stuff prior to my final buffing. It preps my products for final buffing.
Still Learning
I think this is the right stuff to polish most plastics, but I'm still learning. Amazingly Large Quantity and a Good Deal.
Works great!
Use to shine bowls and pens.
The best for plastics and Bakelite
Did a pertect job with the String Buff wheel to maximize the shine on bakelite and remove scratches and polish clear plastic.
