Sanding Belt x 5 - 320 Grit
For use with the expander sanding wheel. Our Aluminum Oxide sanding belts fit all other brands of expanding wheels. 5 sanding belts.
3 Reviews Hide Reviews Show Reviews
Works as advertised
see summary
Good
Good value another great caswell product
Sanding belts
great product and price.
