Make your own Reverse Osmosis water for mixing plating and anodizing chemicals.
This unit will produce up to 50 gallons per day.
Includes faucet connector that allows easy connection to a garden hose.
Three stage filtering system removes all contaminants from tap and well water.
Filter replacements are available and should be changed regularly:
- Sediment Filter (3-6 Months)
- Carbon Filter (after producing 400 gallons)
- RO Membrane (12-24 Months)
