Warm Weather Thinner is a medium-speed lacquer thinner. Use when the ambient temperature is 66°F to 85°F. When spraying, thin 20%. If the Permalac is drying too quickly, and you notice blush or any other adverse effects, you can increase this to 30%. When brushing, thin 10%.
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Hazardous Shipping Info
GHS Info
SDS
