Permalac Strip Thinner consists of a blend of solvents designed to dissolve and remove cured Permalac Original, Permalac EF, Permalac NT, and Permalac SR from metal surfaces without marring the substrate. This material is composed of VOC-exempt solvents.
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Hazardous Shipping Info
GHS Info
SDS
