Standard Hot/Cold Thinner is a regular speed lacquer thinner. Use when the ambient temperature is 50°F to 65°F. Thin Permalac Original, EF 20% when spraying. No thinner will be needed for brushing unless you notice brush strokes or irregularities.
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Hazardous Shipping Info
GHS Info
SDS
