Permalac SR is a 'Scratch Resistant' Topcoat that meets California VOC guidelines is currently available in either Satin or Matte.
Permalac SR is applied over any of our Permalac products to provide a scratch resistant topcoat. It melts the top layer of Permalac & then adheres to it to become a part of it.
- Designed for metal tabletops, counters, doors
- Anywhere you need a scratch resistant surface
- One coat adds scratch protection when used along with Permalac
Perfect for furniture manufacturers, ornamental metalwork and heavy use areas.
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
Hazardous Shipping Info
GHS Info
SDS
