Retarding Thinner can be added to the Permalac Original, Permalac EF, or Permalac NT. It should be used to extend flow time and prevent solvent blush when working in high temperatures or high relative dew points. This will make Permalac take around an hour to set up. Use between 2-5%. Use when humidity exceeds 85%.
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Hazardous Shipping Info
GHS Info
SDS
