Permalac NT Black is a fast-drying, easy-to-apply acrylic lacquer coating.
It is an opaque tinted, low VOC formula which lays down similar to a paint.
Permalac NT Black is highly resistant to environmental breakdown caused by UV, acid rain, and salt.
It has outstanding adhesion to a variety of substrates, including patinated and polished metals, hard woods, and masonry or stone products.
Users report excellent results on copper, brass, bronze, steel, aluminum, zinc, and painted wood substrates.
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
Hazardous Shipping Info
GHS Info
SDS
