Permalac NT Copper Matte is available in either 1 quart cans or a 4 quart bundle.
This color is good to go over roofs & such to make them look like copper or match other copper items while protecting the metal surface.
It is only available in Matte finish. To obtain it in a glossy finsh you would need to use Permalc NT Semi-Gloss over it.
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
Hazardous Shipping Info
GHS Info
SDS
