Peacock Flattening Agent is a matting powder that is compatible with all Permalac products. Add Peacock Flattening Agent to 1 gallon of Permalac to achieve your desired level of flattening.
Recommended Mix:
- Semi-gloss: add 100 grams to one gallon of Permalac.
- Matte – add 200 grams per gallon of Permalac.
Permalac Flattening Agent comes in a 1-lb. bag.
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
SDS
